Hi all!
I have soldered all components but when I measure the DC between 5V and GND (C and D in the manual) it is not 5V. Depending on the position of the voltage regulator the DC-span is between 0,85 V and 4,3 V. Do you have any idea what I have done wrong? I did the Connection at the 5 V solder pads and the scratching.
Best Regards,
Paul
Paul that is great news. Thanks for the update. I will look to do the scratching on the voltage regulator PCB.
cheers,
Dan
Hi Dan!
Yes, I solved it. Well, to be honest it was Thomas who solved it. He sent me a new potentiometer which was pre-scratched when I got it. Long story short is that I did not do the scratching in a correct way.
I hope it will be ok for you too!
regards,
Paul
Hello Paul. I have the same low voltage issue. Have you had any success in solving this problem?
Regards,
Dan Salmon
