    3. USB DSLR keine Funktion
    andreas
    Mai 15
    Hallo zusammen,
    bin Neueinsteiger und teste mich mal durch.
    Leider bekomme ich keine meiner Canon DSLR (EOS M5 oder EOS R) zum laufen.
    May 15 21:02:37 OpenScanPi kernel: [ 37.831885] usb 1-1.1.3: new high-speed USB device number 5 using dwc_otg May 15 21:02:37 OpenScanPi kernel: [ 37.962770] usb 1-1.1.3: New USB device found, idVendor=04a9, idProduct=32da, bcdDevice= 1.00 May 15 21:02:37 OpenScanPi kernel: [ 37.962786] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 May 15 21:02:37 OpenScanPi kernel: [ 37.962798] usb 1-1.1.3: Product: Canon Digital Camera May 15 21:02:37 OpenScanPi kernel: [ 37.962807] usb 1-1.1.3: Manufacturer: Canon Inc. May 15 21:02:37 OpenScanPi kernel: [ 37.962816] usb 1-1.1.3: SerialNumber: Canon Digital Camera May 15 21:02:37 OpenScanPi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3" May 15 21:02:37 OpenScanPi mtp-probe: bus: 1, device: 5 was not an MTP device May 15 21:02:37 OpenScanPi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3" May 15 21:02:37 OpenScanPi mtp-probe: bus: 1, device: 5 was not an MTP device
    Das Syslog erzählt was von MTP device. Könnt Ihr mir einen Tipp geben?
    Danke und ich freue mich auf die Community.
    Grüße Andy
    andreas
    Mai 24
    ein kleines Stück bin ich vorwärts gekommen....
    May 24 12:26:00 OpenScanPi Node-RED[290]: 24 May 12:26:00 - [info] Started flows May 24 12:26:04 OpenScanPi systemd[1]: systemd-fsckd.service: Succeeded. May 24 12:26:19 OpenScanPi systemd-timesyncd[253]: Synchronized to time server for the first time 193.30.35.11:123 (2.debian.pool.ntp.org). May 24 12:26:46 OpenScanPi Node-RED[290]: 24 May 12:26:46 - [info] [python3-function:Run Routine] New file is in location /store_00010001/DCIM/108___05/IMG_2376.CR2 on the camera May 24 12:26:46 OpenScanPi Node-RED[290]: Saving file as ./shared/2020-05-24 12.26.36 - default//2020-05-24_12-26-38.jpg May 24 12:26:47 OpenScanPi Node-RED[290]: 24 May 12:26:47 - [info] [python3-function:Run Routine] Deleting file /store_00010001/DCIM/108___05/IMG_2376.CR2 on the camera May 24 12:26:47 OpenScanPi Node-RED[290]: New file is in location /store_00010001/DCIM/108___05/IMG_2376.JPG on the camera May 24 12:26:47 OpenScanPi Node-RED[290]: #007File ./shared/2020-05-24 12.26.36 - default//2020-05-24_12-26-38.jpg exists. Overwrite? [y|n] >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Version in use: 2020-04-25-17.17
    Kann mir bitte jemand weiterhelfen?
    Danke und Grüße
    1
    Stefan Seitz
    Juni 3
    Hi, ich versuch mich auch gerade dran.
    Ich konnte auch über ssh / putty keine Photos über gphoto machen, _bis_ ich JPG auf der Kamera aktiviert hatte (normalerweise speicher ich nur RAW). In der Software geht es zwar immer noch nicht, aber mühsam ernährt sich das Eichhörnchen :-)
    Stefan Seitz
    Juni 3
    Update: RAW muss ganz deaktiviert werden, dann scheint es aber zu funktionieren!
    andreas
    Juni 6
    @Stefan....
    Das war es. Danke für die Info.
    Grüße
    1
    Sabine Speiser
    Sep. 17
    Hi, Ich komme leider nicht weiter mit dem verbinden meiner Sony a6000. Ich finde nirgends die richtige Dokumentation. Kann mir jemand von euch weiterhelfen? Sie wird gar nicht erst erkannt, steht aber in der Kompatibilitätsliste von gPhoto.
    Wäre super wenn ihr mir weiterhelfen könnt!
    danke schon mal!!!
