I have been working around the issue of the openscanpi:1880/ui not working correctly for a while now. I use a network mapping tool to find the IP of the Raspberry Pi and connect directly to the IP. I have been using the Open Scanner Mini to take scans and multiple photos of insects. The trouble I have been having is that I need to log in using ethernet to a router and then put the wifi password in whenever I move location. This isn't an issue until I have to work in a location like a conference venue where I don't have physical access to the router. I have resorted to taking my network switch with me when I go to demo my work. Is there a way to make this unit more user friendly and just connect with an Ethernet cable straight to the Raspberry Pi and then connect to the UI through the Ethernet port? Also to somehow fix the openscanpi:1880/ui not working issue.
Kind regards,
Hi Peter, to fix the hostname issue, see the section: "Optional: Change hostname" here: https://github.com/OpenScanEu/OpenScan
To be honest, I have not tried connecting the Pi directly to a Computer but this tutorial here should help: https://www.slicethepi.co.uk/connect-raspberry-pi-to-a-pc-without-router-or-network/
After that you should be able to access the UI by entering the given IP address + ":1880/ui"
BTW, when I encountered that issue on one of the long-ago maker faires, I used an (old) mobilephone as hotspot to connect both the computer and the pi to.
