    2. Software
    3. Issues with WiFi
    chiroeurope
    Jan. 21
    Issues with WiFi
    Have built the board for the raspberry pi and it checks out with multi meter. Raspberry pi powers up from it without an issue. The Issue is that I can't get my router to see it on wifi. If I can fin a 90° connector for RJ45, I am tempted to just use direct wired connection as long as that won't cause an issue with the scanner. Please advise on options to resolve this issue.
    Feb. 2
    Didi you modify the wpa_supplicant.conf accordingly? Typical issues are the file ending has to be ".conf" and the SSID name and Password need to be in "". Furthermore you might need to change the country code
    Minghua Kao
    Juni 20
    Wired connection seems to work well too. I normally use wifi but connection is not too well where I am so I sometimes loose connections.
