I'm trying to use the show features view but every time I try it, with different objects and settings, it just fails and I need to restart to do anything else.
Yep, its working again. Unfortunately downloading the datasets works sometimes but most of the time it doesn't. I think ill reflash the firmware that came with the SD card.
Thanks for pointing out this issue. There has been a problem with my dyndns provider (which is needed to forward the requests). But I have solved this issue and the function should work again.
Let me know if it works for you :)
Apparently all problems were solved by reflashing the SD card with a fresh download from the repository.
Also, the default values for delay make the motors stall, I had to increase them.
https://youtu.be/NPaeMjcwhYQ
Thanks for pointing out this issue. There has been a problem with my dyndns provider (which is needed to forward the requests). But I have solved this issue and the function should work again. Let me know if it works for you :)
